Activity › Forums › Adobe Premiere Pro › First time use of PMW-150 Footage in PPro
Posted by Sascha Engel on April 28, 2013 at 5:22 pmHallo,
I am a newbie in this forum, since I am a long year FCP editor. Now, I have footage of a SONY PMW-150 camera (50Mbps, 422, 1080, 25p), MFX files (4audio channels). How can I import this into PPro?
I want to try to work with PPro to avoid spending time on Transcoding. But when I just import the MFX File, it plays the image, but muted.
What do I do wrong?Thanx a lot.
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikangSascha Engel replied 13 years, 5 months ago 4 Members · 12 Replies -
Tim Kolb
April 28, 2013 at 5:43 pmTry using the media browser to bring the material into your project vs using “import”.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Sascha Engel
April 29, 2013 at 5:59 amDid not use PPro for quiet a while…where do I find the Media Browser?
Thanx.Greetings,
Sascha Engel
http://www.youtube.com/taikang -
Sascha Engel
April 29, 2013 at 7:21 amI found the media browser – Problem: The MFX Files do not show up under “Supported Files”, if I switch to all files, they do, but still the same problem: They playback without sound. Maybe MFX files are too much even for PPro. They seem to be unsupported by PPro.
Sascha Engel
Jon Barrie
April 29, 2013 at 8:31 amWhich version of Premiere Pro are you using? MXF may not be supported.
Can you confirm the files are actually MXF not MFX…
if you have the latest version of Pr then the Media Browser is the way to import them. If you don’t have audio with the clips this way then you may want to confirm that the clips actually have audio.
Cheers JB
Jon Barrie
Adobe Video Solutions Consultant ANZ
Jon’s YouTube Tutorial Page
follow Jon with twitter -
Sascha Engel
April 29, 2013 at 9:21 amHi Jon,
thanx for your interest.
The version is CS 5.5 – and yes, the 4 Mono Tracks contain Audio.Greetings,
Sascha Engel
Tim Kolb
April 29, 2013 at 12:01 pmIf they were unsupported by PPro, you wouldn’t see video…
When you bring the file(s) in, how long are you waiting before playback? The audio from those files has to “conform”, meaning that Premiere Pro needs to cache some data nd create some preview acceleration files and that may take a bit depending on how long the clips are. Until the conforming is finished, you won’t get audio playback in the timeline.
There is usually a progress indicator running in the lower right bottom of the interface that is visible while this is happening.
I have a feeling this may be what’s happening while you’re trying to use the clips immediately after bringing them in.
TimK,
Sascha Engel
April 30, 2013 at 7:00 pmHi Tim,
Thanx for that tip. It could be. I will check. I threw a 3min video on the TL.
How long should that take before it’s in the cash memory?Greetings,
Sascha Engel
Sascha Engel
April 30, 2013 at 7:06 pmThat was it! Thanx. But actually the conforming time takes longer than getting it inserted into FCP…so in that case FCP 7 is faster to work with those files.
Greetings,
Sascha Engel
Tim Kolb
April 30, 2013 at 7:18 pm[Sascha Engel] “But actually the conforming time takes longer than getting it inserted into FCP…so in that case FCP 7 is faster to work with those files.”
…as long as you completely discount the fact you had to transcode or rewrap the file to use it in FCP7 in the first place
(which is what I find most FCP editors do when evaluating Premiere Pro’s speed), then sure, you could say that.
I can’t vouch for your system…processor, RAM, etc…I have no idea what drive your cache files are targeted to, how full that drive is or how fast it is…
However if given the choice to transcode every single clip, tripling the data space the media takes up before I even start cutting, or importing native files and waiting for some audio conform…I suspect on a machine that is configured to do the work, this is still faster.
TimK,
Robert D’alexis
April 30, 2013 at 9:55 pmFWIW, I imported a 3 hour 20 min long clip from my Sony PMW-350 which produces XDCAM EX files with 4 audio channels and the audio took 1 minute and 21 seconds to conform.
