Activity Forums Apple Final Cut Pro Legacy Firewire Input Question
  • Firewire Input Question
    Posted by Patrick Morrow on January 1, 2008 at 7:09 pm
    I have an Iomega portable firewire drive I want to use to do remote editing. I use a macbook pro to get footage off a mini dv deck. I want to get the footage to this small drive but I cannot loop it out of another drive since this drive cannot loop it only has one firewire port. I also put it at the end of a firewire chain and it would not allow a file transfer to it. Please help as this drive is pretty useless if I cannot get footage to it. Happy New Year!
    Patrick Morrow
    Zane Barker replied 18 years, 8 months ago 3 Members · 4 Replies
  • Thaxter Clavemarlton
    January 1, 2008 at 11:32 pm
    1. Capture to another drive, then transfer the files to the drive you want.
    2. Use a FireWire hub. (May not work, but it costs very little to try.)
    3. For about $50, you can buy a new FireWire case with looping ports and move your drive into it.
  • Zane Barker
    January 2, 2008 at 2:01 am
    [Thax Clave] “1. Capture to another drive, then transfer the files to the drive you want.
    3. For about $50, you can buy a new FireWire case with looping ports and move your drive into it.”
    For get doing any of that and get a FW express card for your MBP. Having the hard drive on a separate bus then the camera is a good thing to do anyway.
    Here is an example it has 2 FW ports and 1 USB port
    https://eshop.macsales.com/item/Apiotek/EC0002C/
    Happy Editing To You!!
    January 2, 2008 at 8:37 am
    [Zane Barker] “For get doing any of that”
    Thank you for the kind words.
  • Zane Barker
    January 2, 2008 at 2:12 pm
    sorry to be so blunt but an express card is just a far better option.
