Activity Forums Apple Final Cut Pro Legacy Firewire hub
  • Chris Poisson
    March 10, 2006 at 6:03 pm
    Per,
    Everything I’ve heard about Firewire hubs is bad. You can just daisy chain the drives together. I would be smart however to install a Firewire PCI or whatever card so you have more than one bus.
    Have a wonderful day.
  • Mitchji
    March 10, 2006 at 9:55 pm
    I asked a friend how he captures to an iMac (1 FW port) and got this reply:
    Can you capture DV with the G5 iMac to a drive other than the boot drive (one firewire bus)? If so are there any problems or tricks?
    “Absolutely no problems. I upgraded the imac’s drive to a 320gb and could capture to that drive but I have a firewire drive workflow. I capture to a FWHD on the iMac. I use a Buslink 6 port FW hub on the imac. I really like the imac G5.
    Best Wishes,
    Mitch
