Activity › Forums › Apple Final Cut Pro Legacy › firewire drive that supports DV, HDV, DVCPRO HD, SD that is not a Raid
  • firewire drive that supports DV, HDV, DVCPRO HD, SD that is not a Raid
    Posted by Jack Entonces on October 30, 2006 at 11:01 pm
    Just got Final Cut Studio along with a new MacBook Pro. I need to get me a second hardrive, and I want to get a firewire drive that supports DV, HDV, DVCPRO HD, 8-bit and 0-bit SD video workflows.
    Aside from a Raid drive, are there any otherrs that will support these sources?
    Any suggestions? thanks
    Dog Food replied 19 years, 10 months ago 8 Members · 17 Replies
  • 17 Replies
  • Shane Ross
    October 30, 2006 at 11:48 pm
    Any drive with a Firewire 800 connection should support all these formats of HD.
    But what format of SD are you referring? Uncompressed? Then look at the G-Raid by G-technology or the D2 Bigger Disks by Lacie. They are two physical disks in a drive case that are raided together to get you fast performance and handle some uncompressed SD material. Only one stream of Uncompressed 10-bit SD, but three streams of uncompressed 8-Bit SD.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jack Entonces
    October 31, 2006 at 1:32 am
    Thanks for the feedback.
    I probably will only be capturing DV video, not SD.
    One more question:
    will I be able to capture the DV video directly from my camera to the G Drive (not a Raid), via the FW 800
    without any hitches or other problems?
  • Bret Williams
    October 31, 2006 at 1:39 am
    You might also look into an external sata which is faster than the FW800. Make sure you’ve got a connection for it.
  • Gary Adcock
    October 31, 2006 at 2:43 am
    [jack entonces] “will I be able to capture the DV video directly from my camera to the G Drive (not a Raid), via the FW 800 without any hitches or other problems?”
    The Drive can handle capture and playback of DV video with out issue.
    HOWEVER capturing video over the FW takes most if not all of the bandwidth of the bus, so you may experience capture errors when trying to use capture and storage on the same buss, and your mac only has one FW buss regardless of the number of connections unless you have added additional capabilities.
    Almost all of the drive Mfg’s recommend that you get an accessory card for the storage to allow you the highest amount thru-put to alleviate any capture problems.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Jack Entonces
    October 31, 2006 at 4:11 am
    What kind of accessory card, Gary?
    does it go on the FW drive, or on the MacBook?
  • Gary Adcock
    October 31, 2006 at 3:27 pm
    [jack entonces] “What kind of accessory card, Gary? does it go on the FW drive, or on the MacBook?”
    a Firewire card is added to the computer so that you have more than one FW buss. they can be added to both laptops (with an accessory slot either PCA or Xpress card) or in your desktop as PCI ( x or e depending on your model)
    gary adcock
    Studio37
  • Dog Food
    October 31, 2006 at 5:41 pm
    Lacie drive is a JOKE if you plan on traveling with it.. They will come apart (BREAK OPEN).. I have 6 TB of Lacie drives. 6 of the 7 drives that have traveled via fed ex have come apart (at the ends)… sure they could have been packed better… they could have flown 1st class on THE UNITED EMIRATES AIRLINE.. : )
    I recommend the western digital MY BOOK… I have not used it for HD…
    cheers
  • Mat @ lacie
    November 1, 2006 at 3:23 pm
    Hi Dog Food – Sorry your LaCie drives got damaged.
    The LaCie d2, Big Disk and Bigger Disks are made in sturdy metal. When shipped with their original packaging or anything comparable (where the drive does not move around the box or case), they can handle as much traveling as you want.
    Mat @ LaCie
  • Ryan Koo
    November 6, 2006 at 7:08 am
    My LaCie D2 500GB Firewire 800 drive just failed. It’s two years old (one year warranty). I lost everything.
    Yes, the outer case is sturdy, but something about the innards isn’t…
  • Dog Food
    November 9, 2006 at 1:58 am
    Yes the outer case is strong.. But it is in 3 parts.. These parts do not stay together.. YOU kow it.. I know.. The assembly is a JOKE..
    cheers
    AND, you never know what sound the drive will make. I have many LACIE drives.. I am looking at 7 drives right now.. and none of them make the same sound when running…. and please do not say things like the drives are “sturdy”… after all, how many of these drive do you own?
