Activity › Forums › AJA Video Systems › Firewire Bus down…FW PCI and Kona ok???
  • Firewire Bus down…FW PCI and Kona ok???
    Posted by Ron Thompson on January 29, 2006 at 4:21 pm
    I think I’m having a FW bus problem which may require Applecare servicing!
    Question for the pros here… Can I buy a FW PCI card to get me by a couple of weeks? Any issues with the Kona?
    I really can’t afford the downtime now (figures…all the work coming in at once… it couldn’t die over the holidays right?).
    Any advice? I’m looking at the Adaptec 4300 which I can easily pick up at CompUSA. I need to be up and running NOW!….and I know I will need some elements from my LaCie drives. At the very least I can move data to my SCSI drives.
    Thanks in advance.
    Ron
    Ron Thompson replied 20 years, 8 months ago 2 Members · 2 Replies
  • Bob Zelin
    January 29, 2006 at 5:28 pm
    YES – this will work, and it will certainly help you confirm if you have a true FW problem.
    bob Zelin
  • Ron Thompson
    January 29, 2006 at 6:58 pm
    Thanks Bob…
    Yeah…I already have the error codes from the hardware test, so I’m 90% sure its a board issue…unless I’m missing a trick. PRAM and SMU resets didn’t solve the issue either. I have 5 FW drives and a AJA IO that aren’t recognized. My local Apple guys need at least 3 or 4 days to diagnose and swap…I just don’t have that time now.
    Thanks again
    Ron
