Activity Forums Apple Final Cut Pro Legacy Firewire broke after update
  • Firewire broke after update
    Posted by Justin Maguda on September 24, 2008 at 3:33 am
    I have been doing a ton of editing at my school for a project so fellow students could observe but needed to take my work home to finish the project. The problem was that the machines at school were a later version of final cut. So now I was stuck updating to 10.5.4 for the OS and 4.0.6 for final cut.
    After all the updates were complete my firewire capture no longer works. When I proceed to capture a file Final Cut closes completely. If I try to watch the video coming out of my camera before recording it plays at about 1/4 FPS and progressively gets worse.
    I have checked my processors during this time and see no unusual tasking. I am able to capture a m2t file just fine at full quality so that makes me think it is something with Final Cut. I am unfortunately running a Hackintosh but my software is purchased (school discount 😉 )
    SO any ideas of what happen? Did my firewire card possibly get a new driver from the OS upgrade that final cut doesn’t like? Is there a setting that could cause this? Any input would be great!
    Justin Maguda replied 17 years, 12 months ago 3 Members · 5 Replies
  • Bouncing Account needs new email address
    September 24, 2008 at 3:49 am
    Try looking here:
    https://docs.info.apple.com/article.html?artnum=301852
    This seems to be the answer to many of these kind of problems.
    Worth a shot.
  • Justin Maguda
    September 24, 2008 at 4:00 am
    Wow thanks for the quick response I went through that cache and deleted all the old updates but unfortunately no go with capturing. It seems very odd because I can see and control my camera but it is like it is getting a low data rate…but as I said earlier I can capture the m2t file no problem.
    Again thanks for the response but this didn’t seem to work.
  • Mark Maness
    September 24, 2008 at 1:32 pm
    First thing…. Have everything legal and consider rebuilding your computer by installing a fresh legal copy of Mac OS on a new hard drive (or one that you can spare). Then install FCS. It will make a difference.
    Do you have ANYTHING else connected firewire?
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Justin Maguda
    September 24, 2008 at 3:32 pm
    Well unfortunately you can never truly have a legal copy of the OS installed through the Hackintosh way. I think I did see something that was actually a piece of hardware to plug in but required certain motherboards. It instead requires a modified install of the OS which was a ton of work to get going. But you do have a Mac Pro for around $1200. I think I will capture and covert m2t before I reformat that thing, its just too much time.
    Nothing plugged in through firewire (except camera), only USB2.
  • Justin Maguda
    September 29, 2008 at 11:48 pm
    Alright well instead of doing everything in M2t format and then converting using $50 dollar software, I just went out a bought a nice new Firewire 400/800 card from a electronics store with a good return policy. Sure enough the capturing in FCP is now working. Thanks for all the help guys see around the forum.
