Activity › Forums › Adobe After Effects › Fireflies effect
Fireflies effect
Posted by Mfuislimc@aol.com on September 17, 2007 at 12:12 amHey guys,
I am wondering what the best way would be to go about getting something that looks like fireflies are rising up from the ground? or Emerging at night?
P.T.
Mike Clasby replied 19 years ago 3 Members · 2 Replies -
Darby Edelen
September 17, 2007 at 3:49 pmI would recommend looking into Particular, specifically the new Motion Path feature and the other Air physics properties.
https://www.trapcode.com/products_particular.html
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Mike Clasby
September 17, 2007 at 6:58 pmCan you just make a firefly with a glowing tail (another layer parented to the body/wings) then flicker the opacity of the tail with a flicker expression, like Dan’s here:
https://www.motionscript.com/mastering-expressions/random-3.html
The expression is for a 3D light, but works fine for Opacity.
To get the basic firefly “rising from the ground”, keyframe the basic rise (position), to get that erratic movement of fireflies, you can add a wiggle (position of the body), with:
wiggle (1,30)
Change the Frequency (the 1) or the Amplitude (30) as needed.
Put expressions on by, Copying (Ctrl C) the expression, Alt-click the stopwatch (say Opacity), then Paste.
To get brighter bights and Whiter whites, for the tail, see Andrews tut on 32 bit, here:
EarthQuake with 32bpc
https://www.videocopilot.net/tutorials.html?id=33
Anyway, once you get the look you like, precomp the firefly, duplicate it as many times as you want fireflie and move them around so they start in different places.
