Activity › Forums › Adobe After Effects › Fire “alfa channel” to Over lay on Video In Vegas>?
Posted by Canadateck on September 30, 2005 at 2:14 amI have made “Flames/Fire” in Affter Effects, and would like to Render it out with a “alfa channel” so I may use it in Vegas to Over lay onto some of my Videos, I have tried many Render Settings and Veags will not see the Alfa.
Andrew Kramer replied 20 years, 11 months ago 4 Members · 8 Replies -
Brian T
September 30, 2005 at 4:11 amGo to Compostion>Add to Render Queue>Output Module:Lossless>Click on lossless>This will open Output Module Settings>Video Output>Click on Channels dropdown menu>select RGB+Alpha. Now when your file is rendered and brought into Vegas, your flames should overlay on your video. Hope this helps.
Canadateck
September 30, 2005 at 12:32 pmI didnt try the Png,I will now.
“Brian T” I did try that, Maybe I need to reinstall? Could also have to do with the fact that, I’m using a “Plugin”??.
What I did was Make a solid color,then add the effect “Plugin”.Thats it, nothing else. Then Render.
Thanks for the Help.
Michael Szalapski
September 30, 2005 at 1:04 pmWhoa there cowboy. If you’re just using some fire plugin than there’s a good possibility there’s not any alpha to use anyway. Did you check to see what happened if you put something behind that layer in After Effects? Or perhaps clicked that little button to turn the checkerboard on?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Michael Szalapski
September 30, 2005 at 1:51 pmPants! I thought that would be an easy solution for you.
How about a Targa sequence?
– The Great Szalam
Canadateck
September 30, 2005 at 1:53 pmYep, Targa sequence did it..
Thanks guys..This was driving me mad….
Andrew Kramer
September 30, 2005 at 4:47 pmI just tried it. The PNG Sequence does work also and depending on your situation they are much smaller file sizes than TGA. ALthough both work well.
