Activity › Forums › Adobe After Effects › Finished video all white
  • Finished video all white
    Posted by Kristina Klason on March 26, 2023 at 12:42 am
    I’ve made my first couple of videos, build in Adobe After Effects, which is quite new for me. Have used a finished template from envato elements. But when I render the short movies, they all come out white, no image just sound 😣 Someone wrote that it can be that the template can be 16bit and the images used 8bit, and that the issue should be resolved if changed to 8bit, but I checked and think everything is 8 bit alredy. Tried to change to 16bit just to try, but same outcome. Don’t know what to do…I’ve made my first couple of videos, build in Adobe After Effects, which is quite new for me. Have used a finished template from envato elements. But when I render the short movies, they all come out white, no image just sound 😣 Someone wrote that it can be that the template can be 16bit and the images used 8bit, and that the issue should be resolved if changed to 8bit, but I checked and think everything is 8 bit alredy. Tried to change to 16bit just to try, but same outcome. Don’t know what to do…
    Eric Santiago replied 3 years, 6 months ago 2 Members · 1 Reply
  • Eric Santiago
    March 27, 2023 at 3:05 pm
    What format are you rendering too?
    Have you tried AME as well as basic Renderer?
    Render to Prores422 first and see the results.
    Also, try rendering a frame e.g. PSD or JPEG.
