Activity Forums Apple Final Cut Pro Legacy FIne on the timeline, won’t play out of the IO, suggestions?
  • FIne on the timeline, won’t play out of the IO, suggestions?
    Posted by Mark Suszko on April 11, 2012 at 1:21 am
    up-to-date FCP7 and an ioHD with latest firmware, octocore mac pro. Everything I can find is set the same, for an SD analog component output, like I’ve had hundreds of times before. Video plays in the canvas, but the video output on the switcher fed by the io HD is a still frame, that updates to whatever still frame I stop on when I stop the timeline. Hit play, and the live output again is stuck in a still frame while the canvas plays just fine. Spent 4 hours today rebooting, re-rendering, re-setting settings. Thinking of buying a puppy so I can kick it, I’m so frustrated. What else should I try?
    Joseph Owens replied 14 years, 5 months ago 6 Members · 9 Replies
  • 9 Replies
  • Jerry Hofmann
    April 11, 2012 at 1:35 am
    Turn the Io off and then let it sit a bit, then try again. Sounds like a frame stuck in a buffer… but restarting helps.
    Since this isn’t anything new for you, you’ve likely set it up right, but post the sequence settings, source material’s format and any processing you did such as a transcode etc…
    Also might call the good fellas at AJA, the customer service there is the best there is. Bet they can have you up in 5 minutes. If you’ve set it up properly in the Io’s setup, and the FCP settings are all right, and restarting doesn’t help, the next thing I’d do is leave a message in AJA’s customer service phone for sure.
    Also be sure it’s not the switcher… ie, check the output of the io directly on a monitor. All sync signals fed OK?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Michael Gissing
    April 11, 2012 at 2:41 am
    Does your easy setup match the sequence? I have seen that with my Kona 3 if I have an HD Easy Setup with an SD sequence and vice versa
  • Mark Suszko
    April 11, 2012 at 1:28 pm
    All settings identical, far as I can tell.
    It’s not one stuck frame. You park your play head on the timeline anywhere, and the output parks on the same frame to match. But then you hit play, and only the canvas plays in motion, in realtime, with sound. The output stays on the frame where you had parked, until the play head is stopped, whereupon the output immediately updates to that new still frame. Quite maddening.
  • Joseph Hung
    April 11, 2012 at 5:11 pm
    I’m not on AJA, I’m using Blackmagic, but I get that problem sometimes too. Sometimes it just takes a Refresh A/V, turning each on and off, restarting FCP, restarting the system, closing and reopening the canvas window, even turning the monitor on and off or unplugging and replugging the connection. Sometimes it’s just one of these, or a combo, but I’ve been able to get it back, usually after a reboot.
    http://www.tulpapictures.com
    Twitter: @tulpapictures
    Facebook: http://www.facebook.com/tulpapictures
    Mac 2.66 GHz Quad Intel Xeon
    OSX 10.6.8
    FCS2
    CS5
    8GB RAM
    ProAvio 8TB RAID 5 Dual Mini-SAS
    Blackmagic Intensity Pro
    ATI Radeon X1900
    RocketRAID 4322 via dual MiniSAS
    Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
  • Jerry Hofmann
    April 11, 2012 at 7:36 pm
    Call AJA…
    But also try toggling on and off “mirroring on the desktop”. It’s in the Audio/Video settings in the AV Devices tab. Turn it off to see if it streams OK, then turn it back on…
    Jerry
    Current DVD:
  • Michael Gissing
    April 11, 2012 at 9:31 pm
    Did you upgrade AJA drivers recently? The latest drivers are designed for FCPX and are beta. Make sure your drivers are the latest non FCPX versions. It is fairly well documented on the AJA site
  • Jean-christophe Boulay
    April 12, 2012 at 3:59 pm
    I’ll just throw in the obvious one for measure: in the View menu, is External Video set to All Frames? Cmd-F12 toggles it off so you might have done that by accident in some finger-stretching exercices…
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Mark Suszko
    April 13, 2012 at 12:03 am
    No, it is always on “show all frames”, I check it every time I refresh the output.
  • Joseph Owens
    April 13, 2012 at 5:26 pm
    It sounds like a mismatch in settings, but the FCP Output preferences have to also match the sequence. There are some codecs that will not play out over SDI no matter what, like Animation.
    jPo
    You mean “Old Ben”? Ben Kenobi?
