Activity Forums Adobe After Effects Finding the position of a layer once its anchor point has been changed.
  • Finding the position of a layer once its anchor point has been changed.
    Posted by Tom Holmes on September 26, 2014 at 2:39 pm
    Hey Guys!
    So, say if you have a null object and you adjust the anchor point parameter in the layer properties..The anchor point will stay where it is and the object/layer will move by the amount (and in the direction) as changed by the anchor point… this means you can now rotate the null around that point to create a circle…
    With me so far?
    How do i find out the new position on the null object (not its anchor point) so that as it rotates around the anchor point (and as a result move around the comp) i know its position as it moves, as the position property only tells me the anchor points position.
    Please advise guys!
    Thanks!!!
    Tom 🙂
    Michael Szalapski replied 11 years, 11 months ago 2 Members · 1 Reply
  • Michael Szalapski
    September 26, 2014 at 3:32 pm
    I would use two nulls for that. One parented to the other. Then use the toWorld() expression to find the position of the parented null.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
