Activity › Forums › Maxon Cinema 4D › Finding original project from renders
  • Finding original project from renders
    Posted by Richie Henson on November 6, 2015 at 5:49 am
    Wouldn’t it be nice to be able to find the original c4d project from its renders? Especially when the render names bear no similarity to the name of the original file? Similar to the ability in after effects to find the original project by using the ‘Edit Original’ command on an imported output file. Even if the log file contained the original file info for the render? Has anyone found a workaround?
    Plus, why hasn’t Cinema built in the ability to remember the font used when it isn’t available on your particular machine? All other programs show the name of the font used even if it isn’t activated on that computer. I know you can add a ‘to do’ tag to a text object, but who really does that? When you work in an environment where there are many freelancers etc and need to rework jobs, all these things can take forever to reorganise!!!
    Richie Henson replied 10 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 6, 2015 at 2:54 pm
    good suggestions but no Maxon ears here. Put them in to Maxon support
  • Richie Henson
    November 9, 2015 at 3:50 am
    Thanks for the reply.
    I’ve asked Maxon about both issues. I’ll post back if I hear anything.
