Activity Forums Adobe After Effects Find and Replace in After Effects?
  • Find and Replace in After Effects?
    Posted by Michael Combs on May 31, 2006 at 10:47 pm
    Ok, I have a huge project in After Effects that I screwed up the timing on the comps – they’re all exactly 23 frames too short. Now, I’m faced with the task of going through all these subcomps and adding 23 frames to each (something like 128 comps).
    Now, I hit upon the brightish idea of “Wait! Maybe I could open a text editor and do a find and replace for 00:20:06 to 00:20:29. And looking at it – good idea, bad reality.
    So, is there another way that I could go through and readjust the size of the comps, or should I set aside a day to lengthen the comps individually by hand?
    Mylenium replied 20 years, 3 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    June 1, 2006 at 2:43 am
    Javascript would be able to do this at one go. You’re best bet is to put out a call for Dan Ebberts. If you’re feeling brave, you can look at the scripting PDF that would be installed in your AE folder for guidance.
    Good Luck
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Mylenium
    June 1, 2006 at 5:33 am
    I think there is exactly the type of script eitehr at redefinery.com or nabscript.com .
    Mylenium
    [Pour Myl
