Activity Forums Maxon Cinema 4D Finally got the vector logo inside of Cinema… But yet another problem….
  • Finally got the vector logo inside of Cinema… But yet another problem….
    Posted by Kristian Aarli on August 4, 2011 at 11:05 am
    Hi.
    Those who have read my previouse thread about the vector logo problem… Now that is solved and I have got it inside of Cinema 4D.
    But now I have yet another problem. uh! When I got it inside of Cinema I could see it in the work area all all that stuff. The paths is correct also… but when I try to extrude the logo, everything fills to a square. I have livetraced it inside of Illustrator and saved it as an Illustrator 8 file. I think the square could be the canvas from the illustrator project. But I need some help for solving that project 🙂
    Snapshot: 0_creativecowquestion.png
    Snapshot with Extrude Nurbs: vreativecowq.png
    Please Help!
    Kristian 🙂
    Adam Trachtenberg replied 15 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 4, 2011 at 2:01 pm
    Yes, you can see the rectangle surrounding the imported splines. Try this:
    Enter points mode and select the imported splines one by one until the rectangle spline is selected. Then either delete it or select all its points delete them.
    Also, unless there’s a reason to have all of those splines separate, you could select all of them and run Functions>Connect. Then delete the points that make up the rectangle.
