Activity › Forums › Apple Final Cut Pro Legacy › FinalCut 7 issues with Snow Lep
Jeff Greenberg
January 21, 2011 at 3:18 pmSounds like your external drive is spinning down. Under energy saver, set the drives to never. Putting the project on the internal HD will mean almost the same.
Instead of minimizing the app, try using CMD-H to hide it.
Last, you may find that the drives stills spin down. Cocktail is an excellent (shareware) tool to prevent drive spindown.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
Matt Goldschmidt
January 21, 2011 at 3:30 pmIts hanging up , becoming un responsive with the project file on different drive then media
Matt Goldschmidt
January 21, 2011 at 3:37 pmand.. it appears to be hanging up when I launch a project that is on a different drive – so its not the drive.
Mark Maness
January 21, 2011 at 3:47 pmThat tells me two things… Either you have a corrupted project file or corrupted media inside that project.
The easiest test would be to eject an disconnect your media drive, then start FCP and open your project. If it opens, you media will be offline. If FCP works fine, you have a corrupted media file. Searching for this is painful unless you can recapture it easily.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Matt Goldschmidt
January 21, 2011 at 3:51 pmI wish it were that.j Its happening on every project and every project file since I re installed clean snow lep and FC.
The os is solid, so Im guessing there was an error in installing FC
that will be next I suppose
I have done all upgrades before and after installing FC -
Chris Tompkins
January 21, 2011 at 3:57 pmI would start a new proj.
Keep proj files on an internal HD
Keep media on Media Drives
set drives to no sleep.
Set backups to an internal drive.Chris Tompkins
Video Atlanta LLC -
David Roth weiss
January 21, 2011 at 4:06 pm[Matt Gold] “Its happening on every project and every project file since I re installed clean snow lep and FC.”
Did you go into System Preferences and set all energy saving parameters to “never?”
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Alan Okey
January 21, 2011 at 9:03 pm[walter biscardi] “Project file should always live on your internal Mac HD.”
By “internal Mac HD,” I assume you mean the system (OS) drive.
I’ve been using FCP since 2003 and I’ve never saved FCP project files on the system drive. I’ve never had any problems keeping FCP project files on a RAID (media) volume, either on my own either system or on any other system I’ve used.
Can you explain why one “should” store project files on a system drive?
