Activity › Forums › Apple Final Cut Pro Legacy › FinalCut 7 issues with Snow Lep
Posted by Matt Goldschmidt on January 21, 2011 at 2:40 amI have a quad core, maxed out box.
Just upgraded to Snow
If Im running FC, and I minimize the project, when I return to the project
I have the program not responding
Project file and media is on an external drive via fire wire 800This is not a drive issue, Im maxed out with Ram.
I have been editing HD for espn and other networks – box is full blownIm getting ticked.
Ideas?Alan Okey replied 15 years, 8 months ago 10 Members · 18 Replies -
Mark Maness
January 21, 2011 at 3:03 amHave repaired your permissions, trashed FCPs preferences, and run Disk Warrior on your system drive AND your media drives.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Matt Goldschmidt
January 21, 2011 at 3:20 amDisk warrior is very abrasive. I will not do that, but are you saying trash my current FC preferences, and where are they.
Ill run disk utility on my external drive for permissions.
Scott Sheriff
January 21, 2011 at 4:26 am“I have a quad core, maxed out box.
Ideas?”I’m leaning towards bad install of SL, over a hardware (or lack of) problem.
For me the clue is “Just upgraded to Snow”.
Clean install?If you have done a proper install, perhaps your system isn’t as maxed out as you think.
What do you consider “maxed out” and “full blown”? A quad (quad what?) may be sufficient for HD. But these days a 12 core Mac Pro with 32GB or more of RAM would be more along the lines of ‘maxed out’.
Your actual specs, and codec your editing when this happens might be helpful.Scott Sheriff
Director
SST Digital Media
https://www.sstdigitalmedia.com -
Richard Sanchez
January 21, 2011 at 4:31 am“Disk warrior is very abrasive.”
I’m not sure what you’re referring to. Speaking from first hand experience, I’ve had Disk Warrior save drives time and time again, and as long as you have the most current version. If you trash FCP preference, and repair permissions and still have issues, I would strongly recommend you consider running disk warrior on your system drive.
Richard Sanchez
North Hollywood, CA“We are the facilitators of our own creative evolution.” – Bill Hicks
Zane Barker
January 21, 2011 at 4:33 am[Matt Gold] “Just upgraded to Snow”
Let me guess you just installed the new OS over the old one.
A search of the cow will quickly revile that when you are running a Pro App System that you should ALWAYS clone your system drive onto another then white it and install the the new OS clean and then install your Pro Apps clean.
**Hindsight is always 1080p**
Walter Biscardi
January 21, 2011 at 11:34 am[Matt Gold] “Project file and media is on an external drive via fire wire 800”
Big no-no. Project file should always live on your internal Mac HD. Only the media files should live on the external array.
As for the project not responding when coming back from being hidden, not seeing that here on any of our Snow Leopard machines. When you did the clean install of the OS, did you run all the Software Updates before you did the install of FC Studio? And then did you run all the Studio updates after that was installed?
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
Register now for our Open House March 5“Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
Chris Tompkins
January 21, 2011 at 11:36 amExt. FW drive(s) going to sleep?
Chris Tompkins
Video Atlanta LLC -
Matt Goldschmidt
January 21, 2011 at 2:26 pmregarding updates, yes.
I have not heard about having the project file on my internal, and media only on external.
That makes most sense out of all the above.
Im open to more suggestions.
Matt
Mark Maness
January 21, 2011 at 3:16 pmAnother suggestion… Keep your Autosave Vault on a separate drive. I’m sure you have at least four hard drives on your system if it’s maxed out, right? Multiple copies of your projects in multiple locations make recover possible in case of drive failures.
We are currently using a Facilis TerraBlock which just lost a total of three actual hard drives over the past two and half weeks. If I had not backed up my project files in multiple places, we would have been up the creek without a paddle, if you get drift.
Using an off-site backup, like your MobileMe account would be a great way of protection fro your project files. Project files are the single most important part of your editing. Protect them with your life.
Wayne Carey
Schazam Productions
