Final Touch HD monitor
I’m just finishing a 35mm feature film… the process is Dual sync transfer to DVCAM and HDCAM… orginally I was not going to do the onlining and color correction however things have changed and now I will likely be doing this process… I am going to buy Final Touch HD and need a monitor… I was thinking of going with the JVC DT-V1910CG and color correctiong via AJA KONA’s component analog HD… I’ve done some back search in the forum, but have not seen this monitor mentioned… the place that would have done the color corrections had this monitor…
The film will be finished on 23.98 HDCAM… if they go back to film it will be from the HDCAM master…
I’m planning on purchasing a Huge system MediaVault 4110 for the onlining, any thoughts on that also?
I have a DUAL 2.3 G5 with KONA 2/w breakout and 4 GB of RAM…
I really appreciate any thoughts…
thank you,
chris mcguinness
