Activity › Forums › Adobe Premiere Pro › final sequence unplayable in CS4
  • final sequence unplayable in CS4
    Posted by Vuk Vukmirovic on June 14, 2009 at 8:50 am
    I have a big project with lots of sequences and till 2-3 days everything worked fine, but now…
    I work like this: edit a sequence and then copy and paste the whole sequence (with all cuts and original clips) in one big final sequence where I put everything together. I don’t nest, as this is a first version and then when I have all the sequences together I will work only in this big final sequence for final version of the film.
    The problem is that from few days ago, I can not play this final sequence. I press play and it just stands on that frame and the play button under monitor goes back to a stop after few seconds. All other small sequences are fine, I can edit, play or whatever. I tried copying and pasting all the edited material from the final sequence in the new sequence, but nothing changed.
    I will try installing some updates that I found on Adobe site, but didn’t find that it fixes this problem, so maybe someone has a better idea?
    Vuk Vukmirovic replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
