Activity › Forums › Boris FX Particle Illusion › Final Render Size
  • Final Render Size
    Posted by Guladig on April 12, 2007 at 10:52 am
    I’m having a real problem here with final render size.
    I want to output 1 frame at 4000px X 1500px approx as a png file
    for use in photoshop. I set the stage size correctly and use
    pillusionrender to output the image. Problem is I get the final pixel
    size I want but the actual image has not been rendered to fill the stage
    size. The size seems to be the same as the desktop area I have defined.
    How do I achieve the above. Every post I have searched and read in this
    particular forum seems to broach this issue but does not fully explain
    how the final size is achieved. Im assuming the same principles would apply
    as in using a 3D app where you can render any size (dimensions) of image
    your system can handle depending on ram.
    Alan Lorence replied 19 years, 5 months ago 2 Members · 1 Reply
  • Alan Lorence
    April 12, 2007 at 7:42 pm
    1) Set stage size to 4000 x 1500 pix in Project Settings.
    2) Work in pI3 zoomed out until everything is how you want it and save project
    3) render project file in pIllusionRender.
    Output should be 4000 x 1500 (the same size as the stage settings).
    If you’re on a Mac, you may be limited to 2048 x 1500. This would be a limitation of you graphics card driver.
    Alan.
    http://www.wondertouch.com
