Activity › Forums › AJA Video Systems › Final question before purchase of Kona LHe
  • Final question before purchase of Kona LHe
    Posted by Vince Gaffney on January 8, 2007 at 4:07 pm
    I just want to be certain I have this workflow correct before I purchase my Kona LHe. I will be working in 10bit uncompressed SD. The source material will include d-beta, dv50 and HDV. The HDV is where I need to be certain. The deck is a Sony HVR- 15MU. Final Cut 5.1.2. Separate Audio
    Walter Biscardi replied 19 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bob Zelin
    January 8, 2007 at 11:26 pm
    I am confused by your post. You want to work in 10 bit uncompressed SD. Your HVRM-15 will allow you to downconvert right in the VTR to output analog component Standard Def video, if you are working in uncompressed SD. Why would you want to bring in a HD 1080i HDV codec signal into a standard def project, when the VTR will take care of all of this for you ? The same would apply even on an AVID Adrenaline system. Why go in firewire HD, when you can avoid all the aggrivation by inputting a SD analog component signal (with analog audio). You did say that your project is 10bit uncompressed SD, not HD – correct ?
    Bob Zelin
  • Vince Gaffney
    January 9, 2007 at 1:19 am
    sorry for the confusion. the deck outputs downconverted hdv to 720 x480 smpte not 720×486. i’d like the HDV footage to come in downconverted to 720×486 edge cropped. i assume that i can do that down convert with the component input on the kona card so i’m not going from HDV to 720×480 in the deck then to 720 x486 with the card. the d-beta is already 720×486. the dv50 wil get captured to 720×486 via sdi. the only thing i want via f/w is t.c. and deck control while i capture the HDV footage component through the Kona card at 720×486 if that’s possible. does that make better sense? i just want everything the same pixel dimension when it gets in the system.
    thanks, vince
  • Jeremy Garchow
    January 9, 2007 at 1:33 am
    [gaffney film] ” the only thing i want via f/w is t.c. and deck control while i capture the HDV footage component through the Kona card at 720×486 if that’s possible.”
    Yep, it’s possible.
    https://www.aja.com/pdf/support/AJA_whitepaper_HDV.pdf
  • Walter Biscardi
    January 9, 2007 at 1:35 am
    [gaffney film] “the only thing i want via f/w is t.c. and deck control while i capture the HDV footage component through the Kona card at 720×486 if that’s possible. does that make better sense? i just want everything the same pixel dimension when it gets in the system.”
    Yep, we do that with our Sony 15U HDV deck. You need to set the deck to DV via Firewire because FCP will not allow you to control the deck in HDV mode.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Vince Gaffney
    January 9, 2007 at 1:56 am
    thanks
  • Vince Gaffney
    January 9, 2007 at 10:33 pm
    i ordered a new mac pro system today and a kona LHe and want to thank those whom offered their knowledge and time.
    thanks
    vince
  • Walter Biscardi
    January 9, 2007 at 11:54 pm
    [gaffney film] “i ordered a new mac pro system today and a kona LHe and want to thank those whom offered their knowledge and time.”
    Good luck with the install and know we’re here to help any way we can!
