Activity › Forums › Adobe Premiere Pro › Final output settings for standard DVD (assets in 1280 x 720p .H264 59.94 FPS)
  • Final output settings for standard DVD (assets in 1280 x 720p .H264 59.94 FPS)
    Posted by Simon Thurman on January 19, 2009 at 3:16 am
    Hi there,
    I’m sorry to have to ask but believe me when I say I’ve searched every forum I can and Adobes help files! Its got to the point where I have started to confuse myself with all the available settings with what i’m trying to achieve.
    First of all let me explain the set up. I have CS4 master collection.
    I have made a 30 min short film and want to export to DVD so that i can start sending out to various competitions.
    Before I imported all my video assets into premier pro I applied various effects within after effects.
    My original source footage was 720p x 1280 .H264 at 59.94 FPS. When I applied the effects in after effects I rendered out in exactly the same settings as my original source footage as I thought it would be best to have them in HD if I ever want to burn to Blu-Ray.
    I then set up my premier pro porject to the same settings as the source footage(.h264 720p x 1280 59.94 FPS) and created my sequence/film. I then added various sound fx and score elements in 5.1. Again I choose these settings because I thought it would be best to have it ready in the highest quality I can achieve in case I want to eventually burn to Blu-ray.
    Heres were the confusion starts…
    For the time being I just want to burn to DVD. In the export options I have tried several ways to do this. These include..
    MPEG 2 PAL DV 25 FPS widescreen preset set to highest quality, with lower field
    MPEG 2 DVD PAL 25 FPS progressive widescreen high quality set to highest quality….
    believe me the list goes on, I think I’ve spent about 2 weeks now trying different variables and I still can’t seem to find one that works very well.
    The main problem I’m having is that when I play back on a standard DVD player the frames seem Jumpy i.e. the frame rate isn’t great at all.
    I only have the encoders that came with CS4. Surely I can get the finished article to play back better??
    Can one of the Pro’s tell me the settings to use?
    I read that premier handles converting frame rates when exporting very well hence why i left the assets the same as the source footage and set up my project for these settings.
    Should I have converted the frame rate to my final output(25 fps) in after effects before I even entered Premier, would this help?
    I’m really at a loss here guys/gals, can someone please shed some light on this very frustrating final bit.
    best regards
    PS please let me know if you need any other technical information.
    Brian Bacheller replied 15 years, 10 months ago 3 Members · 4 Replies
  • Eddie Lotter
    January 19, 2009 at 5:06 pm
    You may find this thread informative.
    Cheers
    Eddie
  • Simon Thurman
    January 19, 2009 at 5:49 pm
    EDDIE!!! fantastic find, thankyou for taking the time to respond I really appreciate it.
    best regards
    Simon
  • Eddie Lotter
    January 20, 2009 at 2:38 pm
    You’re welcome. Happy editing. Happy editor
    Cheers
    Eddie
  • Brian Bacheller
    December 8, 2010 at 4:45 pm
    Major fakeout…I’m having this same issue and thought this would lead me to the answer, but the link is a dead-end.
    Does anyone have the current URL for this thread??
