Activity › Forums › Apple Final Cut Pro Legacy › Final output is DVD? from proress timeline?
  • Final output is DVD? from proress timeline?
    Posted by Delano Bryant on August 22, 2007 at 10:08 pm
    ANy thoughts? I am bringing up SD and some HD. The SD will be up-rezed into prores timeline. The final output will be dvd studio pro.
    Is that the color red you want to use?
    David Roth weiss replied 19 years, 1 month ago 2 Members · 3 Replies
  • David Roth weiss
    August 22, 2007 at 10:33 pm
    Yes, I have thoughts occasionally.
    Now that that’s settled, what’s your question?
    If I were making a DVD with HD and SD I’d do it pretty much the same way you’re doing it…
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Delano Bryant
    August 22, 2007 at 10:41 pm
    Well the COmpressor that I loved so well has changed. I do not know how to get it to take an export now. It keeps saying not all targets are justified. I don’t understand the quick and dirty way to use compressor.
  • David Roth weiss
    August 22, 2007 at 11:18 pm
    Very little has actually changed, its just looks slightly different.
    1. Grab your exported QT from FCP and drag it up top to the gray bar with the downward point arrow.
    2. Click on the Settings Tab — click on the triangle in front of the Apple directory — clicl on the one in front Apple Devices — click on the one in front of DVD.
    3. Drag the Directory (that’s right, the entire folder) that says DVD Fastest Encode 90 minutes and drop that on top of the blue box that opened up top when you dragged your QT file in originally.
    4. Now Click on the Destination Tab and drop the appropriate place onto the other things up top.
    5. Now hit submit.
    David Roth Weiss
    Director/Editor
    Los Angeles
