Activity Forums Apple Final Cut Pro Legacy Final output is a DV-PAL AVI file?
  • Final output is a DV-PAL AVI file?
    Posted by Xavier De champs on May 15, 2010 at 4:48 pm
    I am trying to export to a DV-PAL AVI file from Final Cut. The quicktime file, I´m converting from is made in After Effects, and is a DV file in a Quicktime wrapper. My final output is DV in a AVI wrapper. I´m trying to convert this, but get artifacts after the file has gone through the export of Final Cut.
    Then I tried using MPEG Streamclip, but the same thing happens. Jagged edges, and artifacts that don’t need to be there.
    As I understand, the DV content should be able to translate without any loss at all, by just changing the QT wrapper to a AVI wrapper. But both of these programs seem to decode and re-encode the file, causing these artifacts.
    I think the term I´m looking for is “transcode”, where you just change the wrapper(header), and not the content. Is there any way to do this on a Mac?
    Xavier De champs replied 16 years, 4 months ago 2 Members · 2 Replies
  • John Fishback
    May 16, 2010 at 6:16 pm
    I’m not at all sure about this, but I recall that MPEG Streamclip may have had an option for installing an avi component. Check to see if that exists and if so, was it installed. I know there’s a check box for recompress when exporting QTs. Make sure that’s unchecked.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Xavier De champs
    May 16, 2010 at 8:41 pm
    Great! That recompress thing looks like it could be it. I will look into it, when I get home. Thanx!
