Activity Forums Apple Final Cut Pro Legacy final mix stereo track??
  • final mix stereo track??
    Posted by Spencer Schilly on June 18, 2007 at 4:26 am
    my sound mixer just gave me my final AIF mix down to put into my sequence. There should be two tracks but only one is showing up. In the browser the clip says: Tracks 2A and in the clip window the tab for the track says: Stereo (a1a2). In the sequence there is only one channel showing up. Do i need to bring in the clip twice and pan to the left and right?
    Carsten Orlt replied 19 years, 3 months ago 2 Members · 1 Reply
  • Carsten Orlt
    June 18, 2007 at 6:39 am
    is either of your audio patches (timeline) disconnected? if yes by editing the stereo file you only getting one channel/track.
    easiest fix: control-click in the bottom audio part on any of the lock symbols and select ‘reset’panel’ from the menu. this should reset A1/A2 source to A1/A2 target.
    can’t see any other possibility!?
