Final Cut Studio 3 – stay with Lion, go to Mt Lion or even Mavericks?
I updated my home iMac 27″ from 10.6.8 to 10.7.5 and sure enugh – my NLE and its apps seems to work just fine. FCS 7.0.3, Compressor, Soundtrack and even DVDSP!
Trying to find info on whether or not upgrade to 10.8 or even 10.9 leaves more questions than answers.
The normal path – install a CLEAN OS will not allow me to install FCS 3, because the Installer needs Rosetta which is not supported in Mavericks or Yosemite.
But upgrading an existing 10.6.8 to 10.7.5 seemed to have worked. I am considering doing this on the production suite at the office (it has an ancient Mac Pro, I think it’s an 2008). One thing that might cause problem is the Aja IoHD with its drivers… I reckon going to 10.7.x would work, but not 10.8 or 10.9?
My home iMac has nothing other than FireWire-disk attached when editing.
And no – there’ll be no FCPX for us as a production company. We will most likely switch to Premiere CC (and sure enough, Photoshop, Illustrator, After effects, etc). Reading on the net suggests that with XML we should be able to convert FCP 7 projects to Premiere CC. And it looks like our HPX500 is supprted for ingestion as well.
