Activity Forums Apple Final Cut Pro Legacy Final cut render
  • Final cut render
    Posted by Rich Rumppe on September 8, 2005 at 3:01 pm
    I’m running final cut 5 on a new G5. I produced a short production on HDV without any issues.
    Now I have loaded a couple of hrs of DV footage using the DV settings. Everything seems to run as it did on my old G4 but when I drag any clip from the view to the timeline…I have to render it to see it in the timeline. I must have something set wrong. Any suggestions?
    Thanks in advance.
    Rich Rumppe
    David Bogie replied 21 years ago 2 Members · 1 Reply
  • David Bogie
    September 8, 2005 at 3:57 pm
    Your sequence is set for HD so it must render DV to run inside the HD environment.
    See the manual for how to change your sequence settings.
    bogiesan
