Activity Forums Apple Final Cut Pro Legacy Final Cut Quicktime to Flash
  • Final Cut Quicktime to Flash
    Posted by Brian Cass on January 27, 2009 at 10:50 pm
    Hi all,
    I have Final Cut Pro 6.0, Mac G5 PowerPC OS 10.4.11 and I want to know how best to make a Flash (FLV) file from either a FCP timeline or a Quicktime file. Can you advise me what program I should obtain? Presently, my FCP does not offer a FLV file option in File Export.
    Brian
    Ernie Santella replied 17 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Denise Quesnel
    January 27, 2009 at 11:13 pm
    Hi, you can export the reference video from FCP and import it into Adobe Flash Video Encoder. It comes with the CS3/CS4 suite. In the Encoder you can specify the settings of the video.
  • John Fishback
    January 27, 2009 at 11:20 pm
    Sorenson Media Squeeze for Flash is another option if you don’t have CS3 or 4. https://www.sorensonmedia.com/products/?pageID=1&ppc=2 Be sure to use the On2 VP6 codec when you encode for the highest quality with either encoder.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Brian Cass
    January 27, 2009 at 11:30 pm
    Thank you for those options. I was thinking CS3 or 4 would do it.
    Brian
  • Ernie Santella
    January 28, 2009 at 12:00 am
    Another option is ‘Episode’. I’ve been using that and it works great. It also does just about any other format you could need. And it’s smoking fast!
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • David Bogie
    January 28, 2009 at 12:15 am
    Depends on what you want to do with or expect to accomplish with your FLV.
    Flash Player will recognize H.264 natively.
    You can also change the extension on lots of different codecs to >flv and Flash will open them.
    If you’re expecting miraculous file compression like you get out of vector-based swf, forget it.
    bogiesan
  • Brian Cass
    January 28, 2009 at 5:06 pm
    Thanks for the information on Episode. Do you have any comparison experience between Episode and CS 3/4 or Sorenson Squeeze? i.e. the quality of the Flash file–is it better than these other programs?
    Many thanks!
    Brian
  • Ernie Santella
    January 28, 2009 at 5:09 pm
    No, I haven’t compared them, but I do have Autodesk Cleaner and Episode is much faster for doing most other conversions.
    Ernie Santella
