Activity Forums Apple Final Cut Pro Legacy Final Cut Pro
  • Posted by Seamie on August 3, 2006 at 10:16 am
    I’ve just swapped over from Premiere to Final Cut Pro. Currently I’m editing animatics and after which I have to do a scene breakdown which requires noting the amount of frames in each scene. In Premiere it was just a case of drawing a box over all the shots in one scene and the amount of frames would appear in the info tab. Final Cut Pro doesn’t seem to have such a tab. I know i can right-click a shot and the frame count is displayed there but i can’t select for example three shots and see how many frames are in them when they are added together. I hope i made this clear??!!
    Seamie replied 20 years, 1 month ago 2 Members · 2 Replies
  • Jeff Carpenter
    August 3, 2006 at 1:00 pm
    Right click the ruler on the top of the sequence and change the measurement to frames. Then use the I and O keys on that ruler to set in and out points on your sequence.
    The length between the in and out points will be displayed in the upper right-hand corner of the canvas window.
  • Seamie
    August 3, 2006 at 3:19 pm
    Cheers thanks mate, a lot of hair pulling saved there, and a lot of time!! Thanks again
