Activity Forums Apple Final Cut Pro Final Cut Pro X Specific Compression Settings
  • Final Cut Pro X Specific Compression Settings
    Posted by Jimena Mora on April 28, 2023 at 12:10 am
    Hello: I just finished a short film and would like to submit it to a Film Festival. They ask for specific Compression Settings like: Max Bit Rate: 4Mbps / Constant Frame Rate. How can I specify this to Final Cut for the export of the film. Thank you
    Jimena Mora replied 2 years, 7 months ago 3 Members · 3 Replies
  • Craig Seeman
    April 28, 2023 at 1:34 pm
    You don’t and can’t in FCP. You do that in Compressor. Use the correct app for the job.
  • Ben Balser
    April 28, 2023 at 2:12 pm
    Most of the time the standard H.264 in the standard Export File preset works just fine for those types of things.
    But yes, if you need something more specific or different, you’d need Compressor to go in and tweak something custom like that, if needed at all.
  • Jimena Mora
    February 8, 2024 at 7:43 pm
    Thanks Ben, with Compressor I had no problem. Thank you!
