Activity › Forums › Apple Final Cut Pro › Final Cut Pro X – Problem with Canon XF Plugin for Final Cut Pro X 2.0
  • Final Cut Pro X – Problem with Canon XF Plugin for Final Cut Pro X 2.0
    Posted by Scott Houck on February 20, 2012 at 5:05 pm
    I installed the the Canon XF Plugin for Final Cut Pro X 2.0. When I launched FCP X (10.0.3) the application would hang on “Loading Compressor Support” and then briefly display my “Storage” drive (internal RAID on a MacPro). I thought it was a corrupt file, preferences, etcetera. Well, it turns out to be the Canon XF Plugin for Final Cut Pro X 2.0. I deleted the plugin and now I am back to working.
    If you are having the same issue, remove the Canon XF plugin (instructions at: https://software.canon-europe.com/software/0040354.asp?model=)
    Cheers!
    Mark Stuart replied 14 years, 6 months ago 3 Members · 3 Replies
  • Michael Sanders
    February 20, 2012 at 7:17 pm
    interesting. I used it last week and it worked a treat. Am using a MBP with Lion 10.7.3
    Michael Sanders
    London Based DP/Editor
  • Scott Houck
    February 20, 2012 at 8:05 pm
    Michael –
    I just tried reinstalling the plugin to see if a third attempt had some charm, but it did not. I am using a 2 x 2.93 GHz 6-Core Intel on a MacPro (tower). Whatever it is, it is not working well on my machine.
    – Scott
  • Mark Stuart
    March 10, 2012 at 2:50 pm
    Anyone tried using this plugin with Sony XDCAM?
    Regards
    Mark
