Activity Forums Apple Final Cut Pro Final Cut Pro X display only 720×486 NTSC with Blackmagic intensity Pro 4K!
  • Final Cut Pro X display only 720×486 NTSC with Blackmagic intensity Pro 4K!
    Posted by Joao Ferreira on December 9, 2020 at 9:01 pm
    Hi, Intensity Pro 4K displays only 720×486 NTSC resolution. I updated Blackmagic intensity shuttle drivers to 11.7 I set HD and UHD resolution in System Preferences but still after launching FCPX 10.4.10 it automatically switches to 720×486 NTSC.
    Any clue? Thanks in advance
    Joao Ferreira replied 5 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Joao Ferreira
    December 9, 2020 at 9:03 pm
    On Davinci Resolve Studio its working fine …
  • David Battistella
    December 9, 2020 at 10:16 pm
    What are your FCP 10 Timeline settings?
    What is the size of the image you are sending out FCP 10?
    Can you create a 1080P timeline or a 4K timeline and try to send that out to the monitor?
    David
  • David Battistella
    December 9, 2020 at 10:18 pm
    What are the CONVERSIONS settings and what happens when you select another Frame size in the FCP dropdown menu?
  • Joao Ferreira
    December 12, 2020 at 1:06 am
    Hi David, thanks for the reply !
    I had try everything ! 4K UHD, 1080P, delete FCPX preferencies . All footage is 4k UHD from a Sony A7sIII.
    As soon as I open Final Cut Blackmagic both app preferencies get the wired 720×486 29,97 and I can’t change anything on either applications, when I close FCPX Blackmagic Intensity Pro 4K go to PAL. As I mention above on Davinci Resolve everything works fine and eliminate any hardware/system problems…
  • Bruce Coxon
    December 12, 2020 at 5:00 am
    The setting for FCPX in Blackmagic Desktop Video Setup is at the bottom of the interface
  • Joao Ferreira
    December 12, 2020 at 5:13 am
    I had try everything ! 4K UHD, 1080P. All footage is 4k UHD from a Sony A7sIII.
    As soon as I open Final Cut Blackmagic both app preferencies get the wired 720×486 29,97 and I can’t change anything on either applications, when I close FCPX Black magic go to PAL. As I mention above on Davinci Resolve everything works fine and eliminate any hardware/system problems…
  • Joao Ferreira
    December 13, 2020 at 12:04 am
    Hi Bruce!
    Shame on me! what a stupid mistake it’s just scroll down!
    Thanks a lot !
