Activity › Forums › Apple Final Cut Pro › Final Cut Pro X 10.4.1 now available on the App Store ????…
  • Final Cut Pro X 10.4.1 now available on the App Store ????…
    Posted by Robin S. kurz on April 9, 2018 at 4:47 pm
    https://itunes.apple.com/app/final-cut-pro/id424389933?mt=12
    (MIN. macOS 10.13.2 REQUIRED!)
    WHAT’S NEW:
    Closed Captions
    • Import caption files into a Final Cut Pro project to automatically create time-synced, connected captions in the timeline
    • See captions directly in the Viewer
    • Use the Inspector to adjust text, color, onscreen location, and timing
    • Create captions in multiple languages and formats in the same timeline
    • Use the new Captions tab in the Timeline Index to search text, select captions, and quickly switch between different versions of your captions
    • Attach captions to audio or video clips in the timeline
    • Extract embedded captions from video to view and edit the captions directly in Final Cut Pro
    • Send your project to Compressor in a single step, making it easy to create a compliant iTunes Store package with audio and video files, captions, and subtitles
    • Validation indicator instantly warns about common errors including caption overlaps, incorrect characters, invalid formatting, and more
    • Embed captions in an exported video file or create a separate caption sidecar file
    • Share captioned videos directly to YouTube and Vimeo
    • Support for CEA-608 and iTT closed caption formats
    ProRes RAW
    • Support for ProRes RAW files lets you import, edit, and grade using pristine RAW image data from the camera sensor
    • RAW image data provides ultimate flexibility when adjusting highlights and shadows — ideal for HDR workflows
    • Enjoy smooth playback and real-time editing on laptop and desktop Mac computers
    • Highly efficient encoding reduces the size of ProRes RAW files, allowing you to fit more footage on camera cards and storage drives
    • ProRes RAW preserves more of the original image data, making it an ideal format for archiving
    • Work natively with ProRes RAW or ProRes RAW HQ files created by ATOMOS recorders and DJI Inspire 2 drone
    Enhanced export
    • The new Roles tab in the share pane displays title, video, and audio roles in a single, consolidated interface
    • Quickly view and choose roles to be included in exported video files
    • Roles settings and enabled/disabled states from the timeline are carried through to the share pane
    • Embed closed captions in a video file or export a separate captions sidecar file in CEA-608 and iTT formats
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    Youtube | Facebook
    Robin S. kurz replied 8 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
