Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro woudn’t launch
  • Final Cut Pro woudn’t launch
    Posted by Zeliha Bozkurt on December 5, 2005 at 11:12 am
    Hi Everyone
    My Final Cut Pro won’t start and I don’t know why? I shut the computer down and re-started but it didn’t work.
    Can anybody help
    It’s version 5.0.2 running on Mac OSX 10.4.2 with 2.7GHz processor and 4gig memory.
    Zee
    David Bogie replied 20 years, 10 months ago 3 Members · 2 Replies
  • Ryun Hovind
    December 5, 2005 at 2:46 pm
    I had the same prob yesterday, did a search and found this:
    Final Cut won’t open.
    1) Trash your preferences by going to User>Library>Preferences>Final Cut Pro User Data>Final Cut Pro 5.0 Prefs. Go ahead and trash the other 2 files too. (Obj cache, Prof cache) See if that helps. FCP will re-create these files when you open the application if they are not in that folder, so it is an effective way to “re-start” to “factory” settings.
  • David Bogie
    December 5, 2005 at 2:52 pm
    It would also help if you included one bit of important information: Did it ever work?
    bogiesan
