Activity Forums Apple Final Cut Pro Legacy Final cut Pro won’t import AE CS4 STILLS
  • Final cut Pro won’t import AE CS4 STILLS
    Posted by Tim Snider on November 13, 2008 at 9:11 pm
    I’m switching over to AE CS4 and I have run into a small issue while importing stills into Final Cut Pro. It appears every still frame format that I render out will not import into Final Cut Pro v6.0.4. I’ve tried .jpg,.tga,.psd. The only format that I have had success with is .psd Multilayer. When I try to import the stills they are greyed out of the file selection dialogue box. I then switch it to view all filetypes and when I select one of the stills I recieve this error message:
    File Error: 1 file(s) recognized, 0 access denied, 1 unknown.
    When I okay this message it does not import any of the stills that I have selected. I do not have this problem with stills rendered from AE7 only CS4. I’ve also made sure that I’m rendering 8-bit files and I still haven’t had any luck. I can render movies without out problems it only appears to have issues with the still file formats
    Any help would be greatly appreciated.
    Tim Snider
    Dennis Leppell replied 17 years, 10 months ago 2 Members · 1 Reply
  • Dennis Leppell
    November 13, 2008 at 9:18 pm
    I don’t know if it’s possible with AE, but I get the same type of error if I try to import images from photoshop that are CYMK; I have to go in and resave as RGB. Possible that a similar type of thing is happening? (I don’t have my laptop, and thus AE, today to verify that possibility).
