Activity Forums Adobe After Effects Final Cut Pro will not import STills rendered from CS4
  • Final Cut Pro will not import STills rendered from CS4
    Posted by Tim Snider on November 13, 2008 at 9:13 pm
    I’m switching over to AE CS4 and I have run into a small issue while importing stills into Final Cut Pro. It appears every still frame format that I render out will not import into Final Cut Pro v6.0.4. I’ve tried .jpg,.tga,.psd. The only format that I have had success with is .psd Multilayer. When I try to import the stills they are greyed out of the file selection dialogue box. I then switch it to view all filetypes and when I select one of the stills I recieve this error message:
    File Error: 1 file(s) recognized, 0 access denied, 1 unknown.
    When I okay this message it does not import any of the stills that I have selected. I do not have this problem with stills rendered from AE7 only CS4. I’ve also made sure that I’m rendering 8-bit files and I still haven’t had any luck. I can render movies without out problems it only appears to have issues with the still file formats
    Any help would be greatly appreciated.
    Tim Snider
    Mark Cookman replied 17 years, 8 months ago 4 Members · 5 Replies
  • Aaron Buck
    November 18, 2008 at 6:58 pm
    I’m having similar problems in AE CS4. here’s the scenario importing AE generated stills into fcp 6.04.
    AE save frame as…psd file – fcp will not allow it to import
    AE save frame as…tga file – fcp will not allow it to import
    ae save frame as…png rgb+a – successful
    ae save frame as…tif rgb & rgb+a – successful
    ae save as photoshop layers – successful
    while the tif, png and psd layered files work fine and the alpha channels remaing intact, i am curious as to why it won’t import the composited psd file or targa images.
  • Brian Berneker
    November 18, 2008 at 9:35 pm
    How did you get it to export layered PSD files from the AE timeline? I have a project I’m doing that needs to be exported to PSD layers, but the only way I can do it is one frame at a time… I’m also using CS4
  • Aaron Buck
    November 19, 2008 at 2:20 pm
    wish i had the answer for you, but i was using the save frame as photoshop layers option also which does not allow you to define an in and out segment but simply saves the current frame.
    i took a quick look through the bridge and also checked to see if pshop cs4 might recognize and import an ae project but no luck. i wouldn’t be surprised if one of the folks in the forum couldn’t figure out a bridge or applescript option to automate that process though.
  • Mark Cookman
    January 20, 2009 at 4:17 pm
    Ive been putting up with this bug for a while – real pain.
    Did you find a solution?
    M
  • Mark Cookman
    January 20, 2009 at 4:19 pm
    For got to say – opening and saving in preview fixes the file to FCP’s liking on my system.
