Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro – when capture is finished, there is only a ‘cancel’ or ‘continue’ button – no ‘finished’ button
  • Final Cut Pro – when capture is finished, there is only a ‘cancel’ or ‘continue’ button – no ‘finished’ button
    Posted by Justin Tan on January 7, 2007 at 9:49 pm
    Hey all, was wondering if you could help…
    I am having a problem with FCP in that when i capture a logged clip (or a set of clips), it finishes capturing and only shows a cancel or continue button – if i hit continue it re-captures everything, and if i hit cancel all seems fine…
    The last time this happened i had random black dropped frames through out the capture – i then realised i had continue capturing when drop out detected (something like that) and changed that to abort…. and all was fine…
    But now it is happening again – I have checked all the settings and I can’t seem to know what it is..
    I am using FCP 5.12 – quad G5 Mac (not pro) with Xraid and black magic multibridge extreme…
    any help would be very much appreciated…
    cheers,
    Justin
    Neil Ryan replied 19 years, 8 months ago 2 Members · 1 Reply
  • Neil Ryan
    January 8, 2007 at 3:11 am
    Have had this, too – come & go!
    Try trashing your FCP preferences but look at the BlackMagic drivers, too – I think this is the issue.
    Make sure you have their approved version for both your OS and FCP versions. Details are on their website.
    Hope that helps.
    Neil.
