Activity Forums Apple Final Cut Pro Legacy Final Cut Pro timeline glitches then quits
  • Final Cut Pro timeline glitches then quits
    Posted by Adam Legere on October 7, 2011 at 2:45 pm
    Hey guys,
    I’m in quite the bind here and have done days upon days of research and still no luck with solving my problem. The subject line I have for this problem is very brief so I will give you a more detailed explanation.
    While editing my timeline I notice some thumbnails of my clips in the sequence become “polarized” indicating that the “glitch and quit” is soon to come. I will continue to work away and will begin to see glitches during playback, the best way to describe this glitch would be to say that random frames cut in and out, accompanied by green, red, sometimes blue screens, as well as “white” noise but sometimes “green” noise (if that makes sense). I will then pause playback, try to play back again and usually within a minute FCP will quit unexpectedly.
    At the same time this began happening I was unable to render due to insufficient memory (which is unlikely because I am running 20GB RAM on an 8 core, and tested it on plain text) and was also unable to record a voice over (which I was able to do until this glitch began appearing). I switched to the other suite (a 12 Core also running 20GB RAM) and had the same glitch and quit issue. I then decide to try it out on my iMac, to my surprise, no glitch and quit, but still insufficient memory. After a little while of playing around with things I solved the memory problem by either one or all of the following; Erased FCP preferences, reset PRAM, got rid of anything in the timeline that may have been corrupt (i.e. jpegs, unsupported media etc, copied and paste to new sequence..) I figured that this timeline would no longer be problematic and had one full day problem free and felt I was in the clear, until today, on my first cut the glitch came back, I decide to check the memory issue and it is not a problem to render, but it is to record voice over.
    So, that, in a nutshell, is my problem, I have considered it to be a corrupt sequence but other sequences within the project still do the same thing (sequences that we have synced audio and video with pluraleyes). This is my first project out of many with this company and am willing to start over again on this project to avoid this problem on future projects but my instinct is telling me even if I start over again the problem will continue. We are using plural eyes to sync all of our audio to video and cutting/pasting from those sequences into our main sequence. We are also running Matrox MXO2 LE on the 8 Core Mac Pro and a MXO2 Rack on the 12 core. At first we thought it was a matrox problem because it worked on my iMac fine but now I don’t know what to think. I hope this description was clear enough as it isn’t a complicated problem but it is something we have tried to fix with numerous solutions so it’s time to seek outside opinions.
    Any help would be appreciated.
    Adam
    Adam Legere replied 14 years, 11 months ago 2 Members · 6 Replies
  • Jerry Hofmann
    October 7, 2011 at 2:54 pm
    Post the properties and format of the source clips, and also post the sequence settings you’re working with.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Adam Legere
    October 7, 2011 at 3:19 pm
    Hey Jerry,
    Thanks for the quick response, here it is…
    Camera: XDCAM EX
    Frame Size – 1920×1080
    Vid Rate – 23.98
    Compressor – XDCAM EX 1080p24
    Pixel Aspect – Square
    Field Dominance – None
    Camera: XDCAM DISC
    Frame Size – 1440×1080
    Vid Rate – 23.98
    Compressor – XDCAM HD 1080p24
    Pixel Aspect – HD (1440×1080)
    Camera: 7D
    Vid Rate – 23.98
    Compressor – Apple ProRes 422
    Camera: GOPRO
    Vid Rate – 29.97
    Compressor – Apple ProRes 422 (HQ)
    Field Dominance – Upper (odd)
    Sequence Settings for Final Project Timeline
    Frame Size: 1920×1080
    Aspect Ratio HDTV 1080i (16:9)
    Pixel Aspect Ratio: Square
    Compressor Apple ProRes 422 HQ
    Sequence Settings for pluraleyes timeline (from which we cut from here and paste into final timeline)
    Compressor XDCAM EX 1080p24
    Adam
  • Jerry Hofmann
    October 7, 2011 at 3:32 pm
    You might try reseating your graphics card. Might be the cause of the glitches.. do this first. If that fails:
    I think your problem arises from the mixed formats. Especially adding GOP structured media with Iframe media. I’d be prone to choose ProRes 422 or ProRes 422HQ. Transcode all source footage to that format If it isn’t already, and see if this doesn’t clear up.
    Jerry
    Current DVD:
  • Adam Legere
    October 7, 2011 at 5:41 pm
    Hey Jerry, We reset the graphics card and still no luck, and as for the mixed formats, I would like to think that was the source of the problem but the fact that it works on my personal iMac fine with no glitches would make me think otherwise.
    Adam
  • Jerry Hofmann
    October 7, 2011 at 8:56 pm
    Try all the mac maintenance stuff… like repair permissions, trash prefs…
    Jerry
    Current DVD:
  • Adam Legere
    October 17, 2011 at 6:32 pm
    Hey Jerry,
    I thought I would get back to you incase anyone else had this issue… It turned out to be a Matrox problem. I uninstalled the software and unplugged the hardware a few times and it didn’t solve the issue, but after speaking with our supplier he recommended that we remove the actual host card and sure enough it worked. I’m not sure if it is a Matrox-Lion problem yet but the supplier is taking care of it now so if anyone else has problems with glitches and is running Matrox be sure to uninstall software , unplug hardware and remove the host connection port or any other hardware ports your computer.
    Thanks again for all the help
    Adam
