Activity Forums Apple Final Cut Pro Legacy Final Cut Pro TC problems
  • Final Cut Pro TC problems
    Posted by Treyfh on May 7, 2007 at 10:30 pm
    My FCP system is having problems relaying correct TC to the Beta SP 2800 deck. When I try to black a tape for instance at 00:58:00:02, the deck jumps to a random TC and the beginning of the tape and starts recording at that random TC. I had the deck checked out and everything is fine. I believe that it is an issue with a setting in FCP or possible the Aja IO which is communicating thru the 9 pin remote connector. Any ideas????
    Gary Adcock replied 19 years, 4 months ago 3 Members · 2 Replies
  • Michael Alberts
    May 7, 2007 at 10:58 pm
    The problem is not with FCP. Nor is the AJA IO at fault. The problem is with the device that sits between the keyboard and the edit chair.
    The deck is probably doing just what you’re telling it to do. Check the underside of the front pannel on the deck. You’re t.c. setting should read INT, PRE SET, and REC RUN.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Gary Adcock
    May 8, 2007 at 12:41 pm
    [treyfh] ” When I try to black a tape for instance at 00:58:00:02, the deck jumps to a random TC and the beginning of the tape and starts recording at that random TC”
    Stop using an assemble edit
    it is compounding your time — use an insert edit after you re-stripe the tape once again.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
