Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Studio 2 Quicktime conversion Problems with HD
  • Final Cut Pro Studio 2 Quicktime conversion Problems with HD
    Posted by Matt Fisher on January 27, 2009 at 12:05 am
    I am having trouble exporting my HD sequence using quick time conversion. The exported file is always out of sync missing some video always in the same place no matter what settings I use to export. I have never had this problem using standard def sequences. I have managed to export using quick time to make a new clip in FCP then exporting that file using qt conversion did work but that route takes twice as long. Any suggestions how I can export my HD sequence properly.
    Matt
    Jimmy Stephans replied 17 years, 8 months ago 3 Members · 3 Replies
  • Chris Borjis
    January 27, 2009 at 12:41 am
    you shouldn’t generally use quicktime conversion.
    It doesn’t do a very good job of down converting (it’s ok but not great like it could be)
    and a lot of times the gamma doesn’t match.
    just export from the time line as a quicktime.
    change the compressor to uncompressed or prores if your worried about
    a generation loss, though this is usually only apparent on DV and HDV sequences.
  • Matt Fisher
    January 27, 2009 at 12:56 am
    Thanks that helps a bit. I am trying to get a smaller file size as well but keep the quality as high as possible. I need the files to upload on youtube in HD. I can go up to 1gb but that is much larger then I would like.
  • Jimmy Stephans
    January 27, 2009 at 1:23 am
    For about $30 they have some great Compressor presets for YouTube here
    https://compressorpack.com/
