Activity Forums Apple Final Cut Pro Legacy final cut pro strobing
  • final cut pro strobing
    Posted by Johnalynn on August 9, 2005 at 11:18 pm
    i’m using final cut pro hd and i can’t get rid of the picture flickering and strobing when the clip has an effect on it. it is set in unlimited RT and Full quality cut to tape settings. can anyone help me solve this problem.
    thanks
    Scott replied 21 years, 1 month ago 4 Members · 6 Replies
  • Bouncing Account needs new email address
    August 9, 2005 at 11:31 pm
    Did you RENDER the effects?
    August 9, 2005 at 11:33 pm
    AND, are you checking your video quality on an external video monitor?
  • Johnalynn
    August 9, 2005 at 11:34 pm
    yes i RENDERED the effects and the monitor has the same results
    August 9, 2005 at 11:36 pm
    My next guess is the obvious:
    First thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions on how to do this.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCPro & FCExpress.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
  • David Scott
    August 10, 2005 at 7:48 am
    Hi
    Another very obvious one. Is the image in your viewer or canvas window larger than the window? Try reducing the picture size to 25% to check.
    Cheers
    David Scott
  • Scott
    August 10, 2005 at 3:17 pm
    Have you checked the field dom setting in sequence settings?
