Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro rendering
Posted by Ayenka on May 30, 2006 at 10:59 amHi all, this is the first time I am using the cow. I’m hoping that it will help decrease costly phone calls from East Africa to frineds in the Uk.
Suddenly, I can’t seem to render on final cut pro. No error message is given. The program just refuses to render. If conversted to Quick Time Movie the product plays in full, but I can;t render. What to do?
Cheers and best wishes.Happy editing and God speed
Jan Bliddal replied 20 years, 3 months ago 7 Members · 6 Replies -
Jerry Hofmann
May 30, 2006 at 1:07 pmTry this: https://fcprescue.andersholck.com/ to remove your preferences with FCP closed. Then from the Sequence menu, after you reopen FCP, select Render all/ and turn on each of the render states there. Then type option+r and see if the renders will get going…
Jerry
Tony
May 30, 2006 at 2:57 pmIs your scratch disk were renders are directed to full? If it is filled up then no renders would be possible.
In anycase check your scratch disk settings.
Tony Salgado
Jonathan Miller
May 30, 2006 at 3:02 pmIf you still need to call your friends for help, you should look into using Skype (www.skype.com) to make the phone call.
It will make it MUCH less expensive.
We all have to call friends for help once and a while!
Good luck!
Jon
TreeLine Productions
Fort Collins, CO USACurrently producing these popular podcasts:
Liane G rozzell
May 30, 2006 at 3:17 pmI had a problem similar to this and it turned out that it was a codec incompatibility between the sequence settings and the material in the sequence. (I was trying to set up an H.264 codec sequence with media made using other codecs.) The sequence looked fine, but would not render until I changed its codec back. No error message, just no render.
Peace,
Liane -
Anders Haavie
May 30, 2006 at 6:40 pmMaybe you don’t have the correct priveleges to write to your render folder (then you will get the error message as you describe). Try deleting your renderfiles folder, and try to render again. You will lose your already rendered files, but FCP will create a new render folder with correct priveleges.
OR use Disk util and run check Disk priveleges.
Anders
Xraid-Xserve-Xsan-Xeverything
Jan Bliddal
May 31, 2006 at 12:55 pmHello Jerry Anders has some trouble with his Internet provider. His utility was to popular and generated to much traffic. But he made a deal with Michael Horton I presume and lafcpug are now hosting i for free.
Let the machine work for you. Not you for the machine
