Final Cut Pro render issue (can’t render)
This is so weird. I have FCP version 5.0.4 running on a G5 powermac running OSX version 10.3.9.
A few weeks ago, I edited a project in HighDef everything went swimmingly. Then the next project I worked on was in SD (a project shot on miniDV) and my preview wouldn’t work and I could not render in the preview. It acted as if the Caps lock was on. I could not render anything.
I did find a work around. To check on an effect I have to shuttle across the effect frame by frame. I can get the project in decent shape, but to view it as a whole I have to export as a quicktime file and view it that way. It works, but it is a pain and eats my time.
I have looked for ever and havn’t see where anybody has had this problem before. I have gone back and reset all my preferances to SD.
I thought it might be a capture issue, but I tested both fresh captured files as well as things captured before this happened.
oh yeah the viewer’s color is green instead of the grey and white checker pattern.
