Activity › Forums › Apple Final Cut Pro Legacy › final cut pro render comes out jumpy. like there are 5 frames missing every sec.
  • final cut pro render comes out jumpy. like there are 5 frames missing every sec.
    Posted by Avi Sliman on August 1, 2011 at 11:30 pm
    hi to all.
    working on a hackintosh machine that i built
    i has 6 gb of ram
    i7 -920
    and a 220 gt graphic card
    working with it for more than a year now-never had a problem with it.
    i started working on material shot on ag-af 101 from panasonic- after logging and transferring it into final cut in pro res -lt 1080 50 i(which is the same way it’s been shot)
    i started editing it and found out that the shots that i changed their speed is a bit jumpy..and there is a blue bar in the render section even after rendering (i checked all the render options in the seq setting and so on).
    i than continued and sent the seq into compressor to finish up with a high quality 90 minutes preset that than i imported into dvd pro and burned.
    when watching it on the dvd player connected to my tv i was shocked to see that the short movie was very jumpy like there were a bout 5 frames missing from every second in the film.
    has any one has a good idea what it might be??
    many thanks//
    avi
    white light productions.
    Avi Sliman replied 15 years, 2 months ago 3 Members · 3 Replies
  • John Pale
    August 1, 2011 at 11:43 pm
    Hmm. Did you use an NTSC preset by mistake?
    30 frames instead of 25 would leave you 5 frames
    By the way…blue bar means unsupported enabler installed.
  • Patrick Sheffield
    August 1, 2011 at 11:47 pm
    I agree – doesn’t sound hackintosh specific…
    Patrick Sheffield
    Sheffield Softworks
  • Avi Sliman
    August 4, 2011 at 10:08 am
    what can i do a bout the unsupported enabler…
    what does it mean???
    i had my pci card burned a month ago i replaced it with a new one//less powerful// and i think that this issue is happening since than..
    i must add that i use the correct preset as i am sending the hole seq strait a way from final cut into compressor..but just incase- i double checked it..
    i freshly installed mac-osx as well as final cut 7 both updated to most recent update(not the mac-osx-don’t like the lion mac-os) on a new hard drive (1TB)
    but it didn’t help-the blue bar is still there ass well as the jumpy exports..
    one thing i have noticed is that now it’s happening even on a dv-material..
    it looks like final cut cannot handle slow motion correctly..
    many thanks for replaying.
    avis144
