Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Render adds extra frames back in to footage shot at 24fps
  • Final Cut Pro Render adds extra frames back in to footage shot at 24fps
    Posted by Marty Elcan on March 6, 2012 at 8:48 pm
    I shot footage at 24fps with a Canon HFS100 and Log and Transfer doesn’t recognize this particular Canon format, so makes the footage 29.97, adding the extra frames in.
    Usually, if I create a sequence for 23.98, and drag footage into the timeline, it asks if I want to match the sequence to the footage, I say no, and it plays beautifully in the new time line — no stuttered added frame look.
    However, there are several clips that still show the extra frame, making for a very static-y look.
    I have tried creating a new sequence at 23.98, and pulling the clip into there,and once again, it looks perfect. But then there’s a gren line, indicating it needs to be rendered. I’ve had mixed results with then rendering and copying it and putting it back in my original timeline. Sometimes it looks PERFECT — 23.98, no added frames, and other times, it comes in with the added frames and stuttered look.
    Cannot figure out how to consistently let FCP convert the footage back to what I originally shot! Any ideas? (Of COURSE I have a project that must be turned in IMMEDIATELY — how rare, right?)
    Using FCP 6 on a Mac.
    THANK YOU!!!
    Marty
    Marty Elcan replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
