Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro: Problem Exporting Quicktime .mov files
  • Final Cut Pro: Problem Exporting Quicktime .mov files
    Posted by Shupfcp on May 7, 2006 at 9:00 am
    I am having some problems exporting quicktime movie from Final Cut Pro 3. I’m currently running on OS10.2, G4, 512Mb.
    Just 2 days ago, I exported a .mov file using Photo-jpeg (best quality) and there were no problems. But today, I tried exporting again and the .mov file only has audio, whilst i just see a white screen throughout. Is there a preference or setting that I’m not getting right?
    Would really appreciate some help on this as I use this fcp function quite a bit and am pulling my hair out because of this.
    Thank you so much in advance.
    shupfcp
    Shupfcp replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 7, 2006 at 4:26 pm
    The white screen usually indicates that the codec used can’t be found… the fix may simply be a trashing of the prefs. Try that first.
    Jerry
  • Shupfcp
    May 8, 2006 at 2:11 pm
    Thanks Jerry,
    trashed the preference and it worked! Thanks for putting me back on track, you’re brilliant!
    shupfcp
