Final Cut Pro ‘Not Found’ Error while Rendering?
Forgive me if I am posting this in the wrong section or anything like that, i am new to this site.
But, I have been using Final Cut Pro for years, with no such errors as the error I received today…
I was rendering everything perfectly fine, and was adding a few texts on top of a few clips. (Typewriter and text generator, to be specific.)Then right after I finished adjusting everything to the text clips, I tried to render, and a dialogue box pops up, saying ‘Not found.’ and ‘Not found.’ ONLY. with a little exclamation mark on the side in a bubble.
I tried everything others have said online, but none worked.
Although, I did get to render most of it by doing it clip by clip, and it all worked fine, until this one very very small clip in the middle gets the same ‘Not found.’ message again right when the rendering reaches 99% or even less.
I’d really appreciate the help, because i need this project to be done, soon!
Thank you 🙂
