Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Log and Transfer AVCHD
Kevin Rease replied 14 years, 3 months ago 6 Members · 11 Replies
Kevin Rease
June 15, 2012 at 4:05 pmMonica, if you haven’t solve your problem here is your solution. You can’t drag and drop the files. You need to open log and transfer, then open the drop down menu in the window and use the “add a custom path” item to direct it to the card and to the “PRIVATE” folder. The will load all of the clips into the log and transfer window.
Kevin
