Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Log and Transfer AVCHD
  • Final Cut Pro Log and Transfer AVCHD
    Posted by Mónica Calderón on June 14, 2012 at 4:03 pm
    Hello,
    I’m having trouble logging and transferring hour long clips of AVCHD footage (shot with Panasonic AG-HMC40P). I’m not scrubbing thru the clips. I just drag the whole entire clip and leave alone. Couple of minutes pass by and it stops. I used different computers and the same thing happens. Please help!
    Freelance Video Editor
    http://www.mocalderon.com
    Kevin Rease replied 14 years, 3 months ago 6 Members · 11 Replies
  • 11 Replies
  • Rafael Amador
    June 14, 2012 at 4:21 pm
    Are you using the log&Transfer option, or just importing the clips?
    rafael
    http://www.nagavideo.com
  • Mónica Calderón
    June 14, 2012 at 4:45 pm
    Hello Rafael,
    I’m using the Log and Transfer option. I open the open the card and select the clips and I add them to the que.. The arrow starts to circle but it stops and an exclamation point takes it’s place. Then nothing happens. I try to restart the transfer on the clip. Nothing happens. I usually delete the que and start all over. Same thing happens. So I tried just one clip then two but the long ones don’t transfer.
  • Rafael Amador
    June 14, 2012 at 6:01 pm
    Google the PANASONIC AVCCAM Importer.
    Is a QT Component that should let you cut the .MTS files in FC without transcoding.
    Rafael
  • Mónica Calderón
    June 14, 2012 at 6:45 pm
    Hello Dave,
    I log and transfer AVCHD to ProRes 422. Can Premiere handle this code?
  • Tina Hedegaard
    June 14, 2012 at 8:33 pm
    I’ve often experienced issues with long AVCHD clips.
    A solution could be to use clip wrapper to rewrap the AVCHD to h264, and then transcode it to prores.
    Yours Sincerely
    Tina Hedegaard
    Editor | Final Cut Pro 7 | Media Composer 5.0 -5.5
    Mac OS 10.6.7
  • Chris Tompkins
    June 14, 2012 at 9:12 pm
    APP cuts it natively…
    Chris Tompkins
    Video Atlanta LLC
  • Chris Tompkins
    June 14, 2012 at 9:20 pm
    Both, anything really…
    Chris Tompkins
    Video Atlanta LLC
  • Gary Milligan
    June 15, 2012 at 2:27 am
    [Tina Hedegaard] “A solution could be to use clip wrapper to rewrap the AVCHD to h264, and then transcode it to prores.”
    That’s an extra step – ClipWrap will transcode to ProRes without rewrapping first. ClipWrap also joins selected clips.
    Gary
    This is me – this is what I do – https://web.mac.com/garymmw
  • Tina Hedegaard
    June 15, 2012 at 10:56 am
    Oh yes I forgot that clip wrapper got that feature. Thanks for the reminder.
    I normally use clip wrapper with avid 5.5.3 and AVCHD
    Yours Sincerely
    Tina Hedegaard
    Mac OS 10.6.7
  • Rafael Amador
    June 15, 2012 at 12:50 pm
    [Tina Hedegaard] “Oh yes I forgot that clip wrapper got that feature. Thanks for the reminder.
    I normally use clip wrapper with avid 5.5.3 and AVCHD”
    Get the QT Component I’ve told you and you won’t need to waist time rewrapping nothing.
    FC does everything.
    rafael
