Activity Forums Apple Final Cut Pro Final Cut Pro Infos
  • Final Cut Pro Infos
    Posted by Robin S. kurz on September 10, 2021 at 2:36 pm
    If you find things such as Final Cut Pro, but especially column sets and audio descriptions interesting (who doesn’t, right??) then you’ll want to take a look at this 😉
    https://youtu.be/9Wg4WUdRaXU
    – RK
    Robin S. kurz replied 5 years ago 2 Members · 3 Replies
  • Mark Smith
    September 12, 2021 at 12:44 am
    Video is labeled Private
  • Robin S. kurz
    September 12, 2021 at 3:31 pm
    Hey Mark! Thanks for the heads up!
    The link thing here seems rather messed up since somehow, even though what you see is in fact the correct URL, the underlying URL is for the deleted version of the video that I had originally posted and then changed! 😒
    So once again, the REAL and correct underlying (i.e. clickable) URL and link is: https://youtu.be/9Wg4WUdRaXU
    Cheers
    Robin
  • Robin S. kurz
    September 12, 2021 at 3:37 pm
    OK, but… WT🤬? I literally had to re-edit the last post three times before it didn’t link to the wrong URL again! Just plain bizarre. 😒
