Activity Forums Apple Final Cut Pro Legacy Final Cut Pro HD 4.5 and Canon XL-H1 issues
  • Final Cut Pro HD 4.5 and Canon XL-H1 issues
    Posted by Doug Cook on May 19, 2006 at 9:54 pm
    Hello –
    I’m just about to start shooting with the Canon XL-H1 and currently running Final Cut Pro HD 4.5. I’ve
    never captured HD footage before with Final Cut HD 4.5, does anybody know if it will capture or do I
    have to buy Final Cut 5.1?
    Doug
    Doug Cook replied 20 years, 3 months ago 3 Members · 6 Replies
  • Todd Beabout
    May 19, 2006 at 10:11 pm
    I believe that you will have to get FCP 5 in order to capture HDV, which is what that camera uses.
    -Todd Beabout
    Vazda Studios
  • Doug Cook
    May 19, 2006 at 10:19 pm
    I checked on the capture presets in Final Cut Pro 4.5 and it offers the foloowing, will any of them work
    with capturing HDV from Canon XL-H1? I plan on shooting 720p24 (16X9).
    DVC PROHD -1080i60
    DVC PROHD -720p24
    DVC PROHD -720p30
    DVC PROHD -720p60
  • Steve Connor
    May 20, 2006 at 7:38 am
    You can’t capture 720P 24 on the Canon. you can capture 1080 24F. FCP 4.5 doesn’t support HDV on the Canon and even 5.1 doesn’t support the 24F mode over firewire, however if you have an HD capture card you can capture 24F via HD SDI.
  • Doug Cook
    May 20, 2006 at 2:22 pm
    So …. I could shoot with the XL-H1 at 1080 24F and capture to Final Cut 5.1 through firewire, is this correct?
  • Steve Connor
    May 20, 2006 at 8:15 pm
    No you can’t – you would need an HD SDI capture card.
  • Doug Cook
    May 21, 2006 at 6:12 pm
    Thanks guys for your input! it was helpful
    Cheers.
